Trans knob replacements
CJJP1984
Cockeysville, MD
1984 CJ-7
For some context, the jeep is an '84 that is heavily modified, ford 302 v8 engine, big body lift, lots of other strictly off-road adds. I bought a new gear shifter knob, but the stick that is on there isn't threaded. The old "konb" which is a T shaped handle was attached with a screw through the handle and the stick. Assume that means I need to get a new stick that is threaded? I finaly figured out how to get the existing stick off, but not sure how to know which new stick to buy.
The Transfer Case knob is trashed; just the plastic piece that was under the rubber cover is still attached. Haven't been able to unscrew that; tried pipe wrench, locking pliers, my teeth, etc....won't budge. Doesn't feel like it's screwed on there. Appears to be pushed down on the stick. The part of the top of the stick that is visible (below the plastic piece) has a diamond-like pattern on it (probably not describing that correctly).
Anyone have any thoughts on the new stick shift identification or how to get the rest of the transfer case knob off?
TSB8C - this is like whack-a-mole....one problem soled one more pops up....thanks again!
Sounds like typical CJ ownership. Good luck and God speed. You will need it.
