knocking
knocking
neal90
for brag
1982 i6 keeping as stock as possible
got a AMC 258 i6 / 4.2l with about 160k on it. The motor runs STRONG. But it knocks when cold... some times the knocking doesn't start for the first 5-10 seconds its running and some times it won't start knocking for 20-30 seconds. And it lasts 3-5 min and than it sounds like a new motor. Is this just piston slap and if so how long can the motor last like this thanks for the help
What's the oil pressure like? Usually when they start knocking the oil pressure drops. Maybe do a compression test as well to see what the engine's like.
the oil pressure is rock solid around 30 psi when cold than 15-20 when hot
At idle? or what RPM? Mine is around 75psi cold at 1200 rpm and then around 30 psi hot +/-5psi. At 2000 rpm hot im at 45psi
A deep knock or clicking?
Deep knock usually a rod bearing.
Clicking is usually normal from used AMC 258 i6 / 4.2l tappets.
Cold mine hits 60 psi on the rebuilt motor. All new bearing and pistons.
20-25 hot.
Compression test will tell you about the pistons and rings. Burning much oil?
If your oil pressure suddenly goes to 0, you've spun a bearing. Pull over and save the bottom end from more damage.
I never heard a knock, but spun a crank bearing. Not too hard to drop the pan and check the clearance with PlastiGage. You're gonna have wear depending on how often the PO changed the oil. . . :D
All the psi are at idle speeds Andy carb is missing the part the controls the high idle at a cold start so it always idles real strong at
Around 700 rpm and its just a loud clicking sound from the
Front top of the motor
