Larger Tires for 86 CJ-7
86 Tex CJ
Garland, Tx
86 CJ-7 4.2L T5 Dana 300 Dana 30 Dana 20 3.31 WT
Want to put 33's on my CJ7 (have worn out 31's). I have T-5 , 3.31 gears, rest stock. Any issues with gearing, axles or fender well interference?
Want to put 33's on my CJ-7 (have worn out 31's). I have T5, 3.31 gears, rest stock. Any issues with gearing, axles or fender well interference?
When ever you go up in tire size your gonna loose a little performance. axles shouldnt be a problem as long as your not beating on it like a tard. as far as fitment goes if your stock suspension your gonna be tight. 2" will get you high enough to handle the 31's
I had 33" tires on my 86cj7 when I bought it and they rubbed terribly, and had 2.73 gears in it. In 2wdh it was a little high, but as soon as you put it in 4wdh it couldn't pull its self up a hill. I put a 4" lift and re-geared to 4.11 and one piece axles in the rear, and up graded the front axles at the same time. I think the T-5 is a little light of a Transmission but you can run it till it quites and then up grade to a medium duty T-176 or even a heavy duty T-18 if you can find one. I would put at least a 2" lift on it 4" would be better if you want to do a little harder wheeling. I like my 4.11s my rpms are 2500 at 55-MPH and 2800-3000 at 65-MPH. But also with your T-5 your RPM will be lower. IMO at least put in a one piece axle in the rear if you have ACM 20 and a 2" lift, a 4" would be better. You may want to re-gear to 4.11s in the future if funds are light.:)
33's will be a bit anemic with the 3.31, IMHO. but it will work. Got lift??
post some pictures so I will know you when I see you on the street.:D
