Locking rear axle
Status
Not open for further replies.
Locking rear axle
Okay, here it is. Not too much doubt now about what rear diff is installed in my AMC 20 rear axle. I could go into it and replace/repair but I am told that the life expectancy of the Trac - Lok is about 50,000 miles and since I plan to keep this jeep for a good long while - I decided to just go ahead and bite the bullet. By sometime this afternoon, I plan to have it ready to drive with the two piece axle shafts changed out to one piece, the axle tubes welded to the housing, and a new ARB air-lock locker installed.
Here's a pic of the diff right after poping the cover.
:chug: Glad to see you're making positive steps! You won't regret your decision once we hit the trails in Aug. Are you going to install a locker up front?
Another thing to consider with that '20' rear.
It's the go-kart size brakes that were used.
IIRC-The Dana 44 used in the last of the CJ's had larger brakes.
The 44 also had thicker axle tubes for less axle housing flex.
IIRC-The D44 used in the last of the CJ's had larger brakes.
You 20 hater LG! [emoji12] My 20 has served me well.
Wooly
The 20 has a bigger ring and pinon than the 44 and can be made to hold up just as well.
I'm for sure not going to have a front locker for a while. Gotta recover from the rear locker first. I need to install new front shackle bushings right now and I think I will do the rear while I'm at it. Just Empty Every Pocket, right? :p
Wooly
Just call'em as I see'em, after work on'em for 35+ years. :D
The only axle I think less of is the D35 used in Wrangles.
The 20 also has thinner axle tubes and smaller brakes than the Dana 44 ;)
Think about a LSD for the front. With a real locker in the rear. Your Jeep will want to 'plow' in tight turns and not turn as you would hope when in 4wd.
Ya know the 20 bashing kinda bothers me. It doesn't offend me or make me feel like I need to change because I know better.
But it DOES tell those who are new that their axle is somehow insufficient...when it ISN'T.
Most people just need to make sure that their axles are tight. Others need one piece. Some need to spot weld tubes and rock climbers might want to truss. But just because it isn't the most robust in its stock form doesn't make it junk.
Most 20's on the road have had nothing at all done to them. Doesn't that say anything at all?
No one is suggesting all you AMC 258 i6 / 4.2l owners need swap engines because there's a stronger one out there are they? Nope they aren't. Same with the 20.
The other thing is Bill already made his decision. I think he made a good decision to install a locker in his AMC20 . He is addressing the axle shaft issue with one piece axles. He's getting the tubes welded. He's going to have a damn good axle when he's done. Now is not the time to tell him to get a Dana 44 . Now is not the time to go over the other options. He made the same decision I would have made. Actually I was faced with the same issue and kept the AMC 20 and improved it like Bill is doing. Back in Minnesota I had a '84 CJ7 and I put in an ARB air locker. I never had any issues with it. Now I have a '79 CJ5 with an OX locker in the AMC 20. It's been running good too although I have had to readjust the linkage once because the cable became too loose to lock the diff.
If you make these improvements the AMC 20 is a good axle.
The great thing about a selectable locker such as the ARB is you can turn it off for tight turns. Also turn it off on slick roads.
No one is suggesting all you 258 owners need swap engines because there's a stronger one out there are they? Nope they aren't. Same with the 20.
Where I jeep in the Mojave and the trails here have proven just the opposite for the '20'. To many failures to count.
I had so many issues with mine, that I could trust it.
If your happy with your 20. Then by all means enjoy it. :chug:
BTW: The ONLY reason I haven't put and '8' in mine is due to the SMOG laws in PRK. :D
That said-My 6 has served me well for 31+ yrs.;)
But that's my point. There's nothing wrong with a AMC 258 i6 / 4.2l and for what the VAST majority do there's nothing wrong with a 20.
I wouldn't want a stock 20 in Mojave but I don't believe for a second that a one piece welded and trussed 20 would have a problem there.
This '80 model is, what, 36 years old? I'm sure not the first owner and have no idea how many went before me or what they did to the old girl. I know it probably has at least a 3" suspension lift and a 1" body lift and someone installed a set of pretty nice 10" wheels that had 33X12" tires. It has a AMC 258 i6 / 4.2l six that runs strong and uses no oil. The 176 Transmission had a top that was screwed up so I replaced the top and it shifts just fine right now. No problems with the 300 transfer. I broke a front axle last winter while trying to get a stuck Toyota out of a frozen stream that he fell through. I now know that the AMC20 rear axle was as cherry as the day it was born. It may not have been one of Jeeps finest moments but it went well over 100,000 miles with a Trak-Loc and two piece axles. Not a bad record for a 36-year old that has almost certainly had the :dung: driven out of it. Anyhow, I'm happy and I'm sure that I'm going to be happier now with the recent work I've done to it.
I'm a bit curious why LG seems intent in discrediting my vehicle and everything that I have done to it. I certainly would not do that to his vehicle. By the way LG, I know a guy down where I came from that had been a mechanic for 35+ years and he's still just as bad as when he started. :confused:
This '80 model is, what, 36 years old? I'm sure not the first owner and have no idea how many went before me or what they did to the old girl. I know it probably has at least a 3" suspension lift and a 1" body lift and someone installed a set of pretty nice 10" wheels that had 33X12" tires. It has a 4.2 six that runs strong and uses no oil. The 176 transmission had a top that was screwed up so I replaced the top and it shifts just fine right now. No problems with the 300 transfer. I broke a front axle last winter while trying to get a stuck Toyota out of a frozen stream that he fell through. I now know that the AMC 20 rear axle was as cherry as the day it was born. It may not have been one of Jeeps finest moments but it went well over 100,000 miles with a Trak-Loc and two piece axles. Not a bad record for a 36-year old that has almost certainly had the :dung: driven out of it. Anyhow, I'm happy and I'm sure that I'm going to be happier now with the recent work I've done to it.
I know plenty of people with the AMC20 that have beat the :dung: out of them and they are still going me included so don't worry to much about it.
Status
