Build Thread Look What I Just Bought (Willys)
PO passed away.
I found a L-134 but not sure it that will be a pain as well. Has a slight knock and no intake/exhaust manifolds. Free.
if someone could tell me how thick the adapter needs to be it can be milled/just a block.
Thank you-Trying to find a v6 or 4cyl to go in it. I guess I can put a shorter input shaft in.
I'm not sure about the L-134 w/the knock and parts needed. Plus trying to get to calif right now.
Hi JB,
Excellent reconaissance. There are some features about this T98 that are - interesting. There is a type of conversion throwout bearing sleeve on it. The face bolt pattern is flipped from what we see in many Jeep T98's. However, conversion to this engine looks possible. It appears to have the BOP pattern on the back of it, which with a Buick bellhousing and a customized adapter kit, it can be done.
Can you do one more thing for me? Is the diameter of the input shaft splines 15/16" or 1-1/8"? Also, if you have a precise measurement of the input shaft pilot tip, we can draft up a quick plan and quote for you.
Thanks.
Eric at Novak
435.753.2513 x20
