Low flow thru fuel filter
81CJ7WY
wow, seems like your having some long term trouble with this. I'd like to address the idle speed as it relates to idle mixture and perhaps that can shed some light here. Idle speed and mixture of the fuel air ratio is directly related. as an engine goes lean it will pick up in idle speed and start to miss erratically before it dies. It is easy to restart an engine if it quit due to being lean. However rich, an engine will lope, like a horse running. If an engine dies due to rich mixture it slowly gets slower in rpm and then dies. it isn't easy to start as it is in a flooded stage. Now if your engine lopes at idle, it is rich, but from what your saying i would guess it is lean, with no rhyme or reason as to its irratic misfire. Also if you end up with a .1 psi on the fuel pressure, (did I understand that right?) which is real close to 0, it is gone into a lean condition as the fuel bowl float level has dropped. Engine rpms goes up. If the fuel pressure didn't die I would look closely at the idle mixture jet being loose or dirty. But since your pressure died, I would suspect the pump. I had a fuel pump go out on me once and it actually blew the fuse as it siezed up, then I'd replace the fuse, it would run fine for 10 min till it got "hot", siezed, and blew the fuse again. I then put in some tin foil gum wrapper, ( not recommended at all!) to get me to the exit off the highway. I eventually replaced the pump and never had the problem again. I know pumps are pricey but at this point it seems like the next thing to do and if you haven't done that, it might be a good thing to do anyways. If it was spark related I would replace the coil next. Also if you want to monkey around with it you could always pressurize the gas tank a few psi and see if it keeps running in your driveway. And if you really want to do that, use a shop vacuum and almost empty toilet paper roll stuck in the filler port. Sure hope this helps in someway.
