Ls swaps
craveman85
- Dolgeville ny
- 1981 cj8, gm 151, sr4, Dana 300, Dana 30, amc 20, 3.73s
I took a good running 2003 6.0 lq4 on trade from someone that I'm probably going to put in my scrambler. Has 80000 miles on it. The truck rotted out and broke in half. I'm going to go with a carb setup because i don't have all the efi stuff like the computer or all of the harness. The Transmission was already sold. What are you guys doing with these ls swaps for drivetrain, motor mounts ect. Are there clearance issues anywhere? I'm probably going with a stick. Probably a sm465 because they're cheap and available in my area. Nv4500 seems very hard to find around here and the two I did find were junk. I have 3.73 gears and will probably keep them. At 60 with 33s should put me at around 2300 rpm which should be ok. I know that a spacer may be required for the flywheel but are there any other bugs I should be looking for? Best headers for the swap? Pictures of anything would be a great help too
load it was fine. they are both good cases. it really comes down to what you want and if you want to spend money for a
