Man does everything change fast.
danray48
- NE Ohio
- 79 Jeep CJ7, 258 T150, Dana 20 soon to be T176, Dana 300
Well, now I've went and done it. I posted a few week ago that I started a brake job, then it turned into pulling my rear AMC20 and decided to go with one piece axels. I blasted my axel, and painted it and clear coat with some cast color paint from Napa. While I was laying under my jeep the other day, I found some holes in the rear of the frame, and the frame had already been patched a little in the same area, so I decided to get some new steel and repair the bad part. (Still haven't got the brakes done) I also found where the spring hanger in the rear is mounted, it only had 1 bolt on each side holding that on. A little sick, but determined to get this right, I thought I'd just check on CL like I always do for a frame. Well I'll be, some guy had a brand new Matkins level 1 frame that a friend was going to build a jeep with about 5 plus years ago and he wanted it out of his barn. Yes, stored inside and never been on the road. Also new shocks, SS brake lines installed, AMC20 rear end with one piece axels and spring over set up front and rear with new springs. New gas tank shield and heavy duty steering parts. This is a beast sitting on old flat 36" tires which will be off tomorrow. I cant wait to get started on this project. I still might drop it down some, because I'd need a staircase to get in it. Plus I don't like em too high. The guy sold the motor that was in it, but I got that guys # 360. I had to wheel and deal, and feel I got a great deal on all of it. Anyway it's mine now, and it's home....
Oh yea, also new brakes, wheel cylinders and brake back plates.....
