Manual Brakes to Power Brakes
Ok ....thank for the replys. I think I'm going to take the booster rod off and cut it toward the brake pedal side ( not too close) , and use a die set and put threads on both sides of the cut and then use some sort of long threaded nut or turn buckle like this....
I'll have to find one somewhat shorter in length though...as for now for the brake switch I "super glued" a piece of hard rubber to the brake pedal tab and it works.....It might be a while but I will post pics when I'm done....
that sounds like a good plan. I would suggest an all thread connector from the home despot. you won't be able to adjust it in place, need to remove the rod adjust and put it back.
The problem with the turnbuckle is you will need a left hand thread die to thread one end of the rod. those are not available at the home despot.![]()
