MC2100 fuel pressure issue
thistle3585
- IN
- 1979 Jeep CJ5 with '72 304 V8, MC2100carb,T150 trans, AMC20 rear diff with locker, Dana 30 front diff, Dana 20 Tr Case, Procomp Springs, Gabriel Ultra shocks.
I had put a Holley carb on but struggled with it so I decided to go back to the MC2100. I hadn't had the MC2100 carb installed for about 6 months while I did an engine swap. I have installed a clear fuel filter between the tank and the pump and between the pump and the carb. In addition, I have a small fuel pressure gauge between the pump the carb. When I had the Holley carb on, I noticed that the filter leading to the carb was 1/2 to 3/4 full with fuel but with the MC2100 it is always dribbling in to the filter but never full despite the fuel pressure gauge reading 6 psi. The filter between the tank and pump is always full. The engine idles well and "cruises" well but stumbles at acceleration. Obviously, it isn't getting enough fuel for acceleration and I'm not sure if that is a float issue, a power valve issue or what. What would cause back pressure causing the fuel filter not to fill?
