Build Thread Mike's 1986 CJ7 (Mid Year) Rebuild
Nice!
Sent from my gas grille using Tapatalk
Spot welds look good, turn your amps up on the 7018 to the 120 range, man your heater looks brand new, did you paint the plastic? What did you use?
Thanks.
I was using 85-90 amps with the 7018 3/32 rod. I'll try raising the amps and see what happens. Thought 120 amps was more for 1/8" rod.
Sanded the plastic box with 180, then wiped with lacquer thinner, then used Dupli-Color low gloss black ceramic engine enamel.
Hmm been a while you might be right on the amps, best to just go up and down til you find the right amps for you and your machine
I don’t have a stick welder yet, but I’m savin’ this for just in case...[emoji106]
I always love looking at your disassembled pictures
Ran a new 5/32" ID wiper/washer hose (Napa $.50 per foot) from the tank to the nozzle nipple. Got some snappy new orange Rain-X washer fluid too.
Noticed, after the fresh air box went in that the washer nozzle is a tad loose. Dangit...!!! Wondering if I can get up there with a small wrench and give that nut a quarter turn now...
Also wondering how many more trips back under that dash my back can take...
Now that should be interesting as well
