Model 20 Axle Swap and Gear Change Help
Canadian CJ 7
- Media
- 11
- British Columbia
- Current Setup 1985 Jeep CJ-258, 6cyl -T-5 5spd 273 gears.
Today, I was told by a mechanic that my rear seal is leaking and that I could have rear end failure if I don't get it looked at. I guess I will be doing the axle and gear swap sooner than expected. I currently have 273 gears in my Model 20 and I want to change them to 355. I believe I have to change the carrier on the Model 20 if I make a higher gear ratio swap where can I find a carrier? I don't want a posi or locker because I drive mostly on the street. I believe my model 30 front axle won't need a carrier if I keep it 355 and under. Any help would be appreciated.
