Motor craft 2100 upgrade
TDHofstetter
Prefers carburetors & points
- Bradford, Vermont
- '73 CJ5 232/T14/D20/D30/D44,
'74 CJ5 Renegade 304/T15/D20/D30/D44,
'85 CJ7 258/T5/D300/D30/AMC20,
(Not CJ: '68 M715 230/T98/NP200/D60/D70)
2-3/4 turns is TOO FAR. A good starting point is 1-1/2 turns out. 2-3/4 turns will make it idle very rich unless the jets are badly varnished.
You can cap off the CTO switch until you've got this problem ironed out, but then you really oughtta' plumb it back in afterwards. You can cap off the line running to the EGR for now (lots of folks run without one, although it makes a lot of difference in emissions).
Have we checked the EGR to verify that it's not leaking exhaust gas back into the intake at idle? You can reach up underneath it with your fingertips to actuate it (lift the diaphragm) at idle... it SHOULD make the motor run a lot worse when you do that. If not, it needs to be replaced.
The PCV isn't - by most definition - a real "vacuum" hose; it delivers "soft" vacuum to the PCV valve to sweep away crankcase gases. You can temporarily cap that off, too, if we're down to that... but if the crankcase is closed, the PCV isn't likely to be the issue in this case.
