Motor timing 180* out?
I'm just wondering, please no disrespect. Have you taken this problem to other boards, if you have how did they react to your seemingly never ending issues, but not seeming willing to address those problems directly?
I admit to have had several long drawn out issues, but mine have a easily followed trail of occasionally folly, definitely listening to those that have already treaded the path I was on and in the end I have found a satisfactory conclusions due in no small part to the advice freely given on this one board.
With that I say good luck to you sir, but consider this, if you can't fix the CJ, there are many perfectly good Toyotas and Nissans waiting for a good loud muffler can and a body kit. A still decent CJ can always use a good home.
Yes indeed Hedgehog, I am a member of 5 or 6 boards, amongst them Jeepz, JeepForum, Military jeepers among others. My neverending issues are primarily on account that I have very little free time to work on this Jeep which until September, was running just fine as my DD
Why didn't you leave it alone? :confused:
It ran fine didn't it?
When you reinstalled the dizzy, the drive gear inside the engine moved the rotor so it doesn't line up with the rotors post when it should.
Hi LG, hope you had a good Christmas. I was leaving it alone, save for preventative maintenance. What got this debacle going initially was a sunken float in the carburator and leaking throttle shafts. When this was not the last fix I received several messages about ignition timing, distributor position, investing in a DUI system (which I would if I weren't so broke) that led me down this long and winding road, so to speak.
The distributor was positioned in such a way that the vacuum advance module was pinching against the upper radiator hose. Using the old finger over the no. 1 spark plug hole I re-established TDC (as shown by my pics) but it is not out of the realm of possibility that I may have installed it 180* out, but I'm leaning toward a large vacuum leak, if i can find it.
The picture you show'd had minor contact of the vacuum hose on a secondary coolant line.
Correct? :confused:
I honestly have stopped believing that running is the point.
It runs but only with my foot on the throttle keeping it at 2000 revs
That's only because the advance curve is let'n it kinda run.........:rolleyes:
What fun would it be if something/anything ran as well after wrenching as it did before. There is no end of good advice to ignore now.
No end of good advice to ignore :p I like that!
FINALIZED
Black Betty is on the trail again, idle down to 600, timing set and running smooth....at long last and 136 posts/counter posts, Thanks to all whom have posted their insights and opinions. But for one final pitfall, dropped the throttle return spring and it's lodged somewhere between the body tub and Transmission . A quick trip to my best friends' place and it's now FINALLY on track. Now on to the mods before this issue began.
You got that right Torxhead, if I see anyone else posting about these AFB's or AVS's flooding I'm going to cut and paste what I've learned
