My ongoing saga
CJim7
Crazy Sr. Respected Jeeper
- Media
- 1
- Twin Falls ID
- '84 CJ7 - 430hp 401 on propane - T18a/D300 twinsticked, Superior axles, Lockers, full boatsides, Warn 8274, OBA, 36" TSL's.
As some of you have been reading and offering advice/insight, I've been having issues with my freshly rebuilt 401. I finally got it running only to be confronted with some bad issues.
Anyway, I pulled the dizzy (thanks Cheapjeap
) and a valve cover and checked oiling again. This time, as I spun the oil pump shaft with the priming tool, I got no oil to the rocker assemblies...
Odd I thought since I had checked all this beforehand and had primed the pump confirming oil to the rockers.
So I pulled the oil pump off and what would normally be one gear that slides onto the boss and another gear with the shaft....turned out to be not what I expected. The shaft had broken off the drive gear, rather broken free, and was not turning the gears.
I've seen this only one other time with a new set of gears, not on mine, but I guess it was my turn.
I reinstalled another set of gears and reprimed the pump. Got good flow to the rockers. I still have yet to drop the dizzy back in and fire it up...
My only wonder is how bad is my engine screwed up now running dry
Dammit
Dammit
