Need help please
F4u5T
Ok guys,
Im gonna go ahead and say im brand new to old jeeps
I have a 85 CJ7 , with the inline 6 AMC 258 i6 / 4.2l and it has a automatic Transmission . The Transmission cooler lines are leaking which I am trying to replace.
The "skidplate" seems to be slightly tweaked and is not allowing me to drain the Transmission .
I have loosened the bolts on the plate and there is alot of weight there, when I push up on the plate the whole Transmission moves and I did not see any of means of support other than the plate.
I have a seal for the bottom of the Transmission the po gave me that needs to be replaced aswell but im a bit wary of removing the plate, is this normal.
also the Transmission cooler was just wire tied to the front of the grill on the CJ, I would like to repipe it to is proper location - which I would think is directly infront of the radiator but I do not see any factory holes for the pipes there?
best I can tell its a TF 999 Transmission
