Need help with axles in 1981 cj5
funderburgh22
Choctaw
‘81 CJ5, no engine, no trans, no tcase, d30, amc20
i bought a 1981 CJ5 that is a roller only and has a Dana 30 front AMC20 rear. i am wanting to run 33s and do a little offroading mostly on road use. the AMC20 rear diff was welded so i am looking for a replacement. i dont mind welding, mods to make an axle fit. should i get a ford 8.8 or is there any toyota axles that would work? i dont want it to be super wide but as long as it doesnt look stupid im open anything even if it means switching the front
The AMC20 with 1 piece shafts will be fine for mild offroad and 33s. A set of 82-86 CJ7 (or 8) widetrack axle will be the easiest and cheapest swap. If you find a set from a 4 cylinder, they'll probably have 3.54 or 4.10 gears if factory. The CJ WT axles will gain you 3" of width.
An Explorer 8.8 is a good axle, but the wrong bolt pattern with no good option for a matching front lug pattern. You could run wheel adapters, or just different wheels for the front and back. Or go big with a C clip eliminator kit with the correct pattern. For the front, you'd be looking a Scout axle, FSJ NT, maybe a narrowed FSJ WT or GM. You'd end up 8-10" wider than you are now (about stock YJ/TJ width)
F150 8.8s are the right bolt pattern, but are full width (65") so 12-15" wider than stock.
I know nothing about toyota axles.
For your uses, I see no reason not to go with stock CJ axles.
:agree: and :ww::dbanana::banana:
Moser 1-piece axles might be the way to go.
What R&P ratio do you have in the axles?
What carrier-LSD, DL or open?
Yeah that’s what I was afraid of lol, I’ll probably just rebuild the AMC20 unless anything else comes up. Hard to find anything from a CJ7 or anything like that, but I’ll keep watching. Thanks!
Pretty sure it’s 3.54 and LSD, What all do I need to recover from a welded diff?
Welded gears.
Pull the R&P with case and toss it, or sell it to someone to run offroad.
Should be plenty of used inners for a 20.
Welded gears.
Is it okay to reuse the carrier?
I wouldn't, probably was over stressed. Get a replacement carrier for 3.0s and above or a aftermarket one with a locker or lsd. As mentioned above one piece axles and good carrier with 3.5's or above gearing, AMC20 will handle almost all offroading duties without a problem.
You need to open the cover for inspection. Some weld it solid others not so much. Depending on how it’s welded you could reuse the R&P
I see carrior being used to identify the case. The case holds the side gears and the carrior holds the case, side gears, and R&P.
I have a narrow Trac Dana 44 already set up for a CJ7 with open 3.72 gear's
Sent from my E6810 using Tapatalk
