Need help with fan shroud.
1 Bad CJ5
Denver, CO
1979 CJ-5 - Chevy SB 400, Muncie SM465, D20 T Case, 33" GoodYear Wranglers. AMC 20 Rear w/ 1 piece shaft upgrade, Ox Locker and 4.10 gearing. D30 Front w/ 30 spline shaft upgrade, Ox Locker and 4.10 gearing. Future - 4" lift, headers w/ custom exhaust.
Hey guys, I was looking to put a fan shroud on my 79 CJ5 and I cannot find a shroud that is wide enough (measuring driver to passenger side) to fit. I measured the bolts at about 26 inches from middle of bolt to middle of bolt, and everything I find is 22 or 23 inches. Anyone have any ideas? I do not have a custom radiator, everything is bolted up in the stock mounting holes up front.
You could go to a radiator shop and have one made. Also check Summit Racing, they have all kinds and sizes.
I have the stock one off a '83 CJ5 with a AMC 258 i6 / 4.2l . If you think it will work you can have it.
I saw that Quadratech has them for sale too.
The Omix Ada fan shroud bolted right into my '78, but I did have to trim clearance for the drain petcock and lower radiator hose. I'm waiting on parts for the Contour/Mystique fan conversion, but when I'm done I'll have this Oxix Ada shroud spare.
