Need Help!!
Need Help!!
etempleton
florida
1983 cj7
Dont do much as far as mechanics on my own ride decided i was going to change out break pads. I got in to it then noticed everything needed replacing. pulled axle new bearings etc. put everything back together now it wont roll when its in gear??? i have to put it in 4 wheel to get it to move. Anyone know what i did wrong or could have messed up putting it back together? any help is appreciated again im no mechanic.
Thank you
Could be that the brakes are adjusted out to far. The problem must be in the brakes or the bearing installation.
I would start by lifting each wheel and see if you can spin the tire to find out which one or ones you are having trouble with.
Make sure it's in N and the hubs are unlocked. Tell us what you find.
Also tell us what all you changed.
