Electrical Need Some Electrical Help!!!
I have been through this before, owning this CJ and others for 18 years, but still helps to have some input.
I just finished restoring my 86 CJ back to Great condition and had all the lights and guagesworking 2 weeks ago, now things have changed. I dropped the fuel tank, changed out the sending unit and cleaned up the rear light conections and after that I have an issue with the front lights being very dim
I have not remounted the new high beam switch on the floor yet, deos it get it's ground from teh floor pan and screws? I am also in the process of putting on a Meyers plow and wiring the lights ( Nightmare) and was drilling a hole in the dash near the light switch too add a toggle when I might have hit something behind the dash and saw a quick spark or two
Now I have NO dash lights, no rear lights, Brake lights and the headlights turn on and are dim as hell. I have also been messing a bit with the front headlights out and in and battery connections on and off a couple times..
Where should I start?? You think I did something to the new Headlight switch??
was through years of play
I am a Happu Camper again boys. I have been working on this Jeep from every aspect of it for 15 years, but sometimes it takes some refresher suggestions from a fresh troubleshooter, Gotta love the CJ
