Need some help 1979 CJ 5
gatorbait7614
Charleston SC
I have a 79 CJ5 with AMC 258 i6 / 4.2l inline 6. Last week I dropped the gas tank and replaced the fuel sender unit thinking that would get my gas gauge to work. Gauge is still not working but that's not a big issue for me. The biggest issue now is that the jeep wont start. I replaced the fuel pump, fuel filter, and lines, getting gas into the carb but wont fire up. I checked the plugs and I am getting spark....Any advise would work....Thanks
Are you sure that you got the hoses back on the tank right? Blow back through the return line and if you can hear bubbles, You've got them wrong.
I did the same thing last year. Ended up that the fuel lines were pinched between the top of the tank and the hangers. Try loosening the hanger straps and wiggle the fuel lines out away from the straps.
Also, if your sending unit didn't fix the issue it may be the ground wire from your sending unit to ground or from your gage to ground. If neither of those, your gage is probably burned up
Bet you either crossed the lines or they are pinch'd.
Can you blow trough the line that feeds the fuel pump(take the gas cap off first;))
