Need u bolts
Need u bolts
CD Long Jr
Newark, De.
87 YJ
2010 Dodge 3500 Mega Cab diesel dually
I had to remove the u bolts from my YJ with a grinder and Dremel tool. The PO didn't apply nev-r-seze when he installed the lift kit. On each side, one u bolt was lond enough that 4-5 threads were showing on one, but the other, the threaded part was only 1/2 way thru the nut. How do I measure for the correct size u bolt and where do you recommend I purhase them?
Not sure I'd want to put Never Seize on my U-bolts.
What's everyone else think?
I never use never seize. I use locktite. It does the same thing as never seize; it prevents rust or corrosion from seizing up the joint or nut. Plus locktite keeps the nut from getting loose. Never seize is like a lubricant.
If you use Locktite, use the blue stuff, red is permanent and will need a boat load of heat to get it release. :)
Most machine shops, and all driveshaft shops can make U-joints to any size you need them. You can even buy them over the counter at most auto parts stores, using the info that BusaDave listed above.
Hi Busa, mate can you help me a little. What are locklite? And how they are used?
orielly has several u bolts in their "help" section
$20.00
  10.0%
