New to Site
New to Site
DE in IA
Prole, Iowa
Hi all. Just registered for this site. I recently purchased a "Franken-jeep" and am trying to get it running. It appears from the research it is a 1945ish Willys MB but the motor serial number on the engine is for a CJ3a . It is an L 134 engine. It kinda ran when I got it but was real hard starting. I put in a new electronic distributer and coil, new solex carburetor and a new fuel pump. It had a old electric fuel pump on it that was full of sand so figured the fuel system was probably contaminated so decided to change out what I could.
I am pretty sure the distributer is in right as there is only one way to put it in with the slot. I have had another friend make sure the plugs wires are right.
I put a Holey pressure regulator on the fuel line and set as near as possible to 2 pounds but it still floods and fills the intake manifold with raw fuel.
Any thoughts or suggestions would be greatly appreciated.
Welcome :chug: I'm not familiar with the solex carb, but it sounds like the float is too high. Maybe stuck needle/seat?
Since you found sand in the fuel pump, I would suggest cleaning out the entire fuel system, starting with the fuel tank.
Solex is a French carb manufacturer. I thought they only made scooter carbs, though.
-Jon
My Solex was flooding and it was due to a stuck float/needle valve. I open the float bowl and got the it unstuck - no more flooding.
Thanks for the thoughts. I did completely flush out the tank and new fuel lines before installing the new fuel pump and carburetor. I put the Solex on to replace the one that was on it.
Thanks for the advice.
-Jon
Scooter gas mileage out of a CJ... ⛽
"This baby gets 65 mpg, but the top speed is 25 mph... " 😄
"Libertatem Aut Mortem"
"This baby gets 65 mpg, but the top speed is 25 mph... " ��
And you have to peddle it to get it going :D
No No No that would be moped mileage.
Peddle to start = moped
pull a rop to start = mini bike
kick or electric start with motor suspended on rear swing arm = Scooter
Sore leg from kick starting + standing on the side of the road = Harley-Davidson
Keeping you guys straight is a constant effort...... :)
<snip>
Wouldn't that be
fractured bones, extensive soft tissue damage from kick starting + curled in fetal position on side of the road = Harley-Davidson
-Jon
I would give a call to Walcks 4wd. Great guys to deal with. Google it. I haven't gotten savvy enough with this phone yet to provide a link
My H-D really didn't kick back enough to hurt, but my BSA was another story all together. I still hurt just thinking about it.
Wouldn't that be
-Jon
No, that's Kawasaki... 😁
You forgot, "no toes, from riding in flip-flops"...
