Newly Rebuilt 4.2 is now oil smoking pretty badly
RQCinLHT
I got my engine machined recently and I did the assembly. I checked all my tolerances and clearances to be sure all was to spec, and it was. I'm a machinist by trade, and have a full set of mics and gages to check with ten-thousandths precision. No plastigage for me. The only thing I couldn't check however was my valve seals and valve guide clearances, I had the head work done by the machine shop. At fire-up and for a good week afterward, all was well. I had checked the plugs a week in, and they showed signs of good burning.
After I drove to the station and filled the gas tank full the next day, it has steadily been blowing oil smoke. It puffs a lot of it when I bump the throttle, and it blows a noticeable amount on steady RPM. You can hear a steady misfire due to the oil consumption. It started off slow, and then built up to what it is now.
Before this full gas fill-up, it has never been full since I bought the Jeep, and I'm not sure how long its been before that since it was gassed up all the way.
This stuff has me beaten down pretty good, it just makes no sense that it should be burning oil like this only 3 weeks into running on a fresh motor.
Is it possible that the mechanical fuel pump may have gone bad? Gulping engine oil thru the crankcase and feeding it to the carb? I also am wondering if the full tank maybe dissolved some crud into the tank, and now I'm burning it thru? I hope someone might have had a similar experience on this they can share.
