Notch in fender for more leg (belly) room
- Media
- 57
- Frederick colorado
- 84 cj7, 91 cherokee, 78 chevy 3500 pu, 78 CJ7
but it is, for the most part up under the seat. A little honest effort and I mayeven be able to drive it this weekend.
Nice metal work. Before painting I probably would have moved the air gun and masked off or painted the tie downs.I really like that color yellow and who can argue with the time proven durability.
That’s not the way I do it.
On mine, I make a straight cut right where the factory roll bar bracket ends, from about 1” from the outside wall toward the center of the tub. Then follow that line to the floor.
I then make another cut, exactly the same about 2”-3” forward... just before it interferes with the top, front, inside beveled corner. Resulting in two parallel cuts.
Then a horizontal cut along the floor.
One last cut on top, following the outside of the tub, 1” from the wall.
The piece removed is simply an “L” shaped chunk of sheet metal.
Next cut the front angled portion lose from the floor, inside and front. Then again, 1” from the outside wall.
Slide the front portion to the rear and butt weld the seams together.
The seat belt attachment remains undisturbed.
There will be an opening, on the front bottom edge and along the outer wall. On the bottom edge I simply use a short piece of 2” x 2” x 1/8” angle. The outer wall I recycle some of the steel I cut out or new 18 ga, bent to fill the gap, then welded into place.
After buffing down the welds and painting it impossible to see the modification unless one is very familiar with Jeeps.
I tried... and failed miserably. Look in my gallery pics, they are there too. If that fails I can email them to you.Please try the pictures again, I can't open them in an image large enough to see what you did.
