Notch
Notch
ken98k
North Pole, Alaska
{1980 cj-5, 258, t-176, d300 amc20 rear, D30}{1974 cj-5, 304, T-15, D20, D30 front, D44 rear}{1973 cj-5, 304, t-98,D20, amc20, D30}
{1990 yj 2.5L i-4 AX-5 NP231 Dana 30 front Dana 35c rear}
1996 XJ Cherokee 4.0 HO
{2000 silverado}
{1979 Cadillac Sedan DeVille}
Can anyone tell me what the v-notch above the rear wheels is for?
Old style top bows. Left-over from earlier models. I believe it was an M38A1 thing.
My CJ5 is an 80 and does not have that feature so I'm guessing it must have been part of the 1976 changes.
What else got changed for 76?
Wow, let's see...off the top of my head...
1) Windshield became laid back further, narrower at the top, and moved the wiper motor to the inside.
2) different front parking lights and rear tailights.
3) steering column and wheel
4)seats, frame and cushions.
5)dash layout
6) heater controls
7) windshield latches turned to knobs
8)roll bar
9)deleted
10)floor pan shape, especially over the tranny.
11) Door mounting brackets changed.
12) frame became wider towards the back
13)fuel tank filler neck became narrower
14) deleted
15) cowl vent grille changed size
16) deleted
17)tranny options changed
18) tool box under passenger seat was eliminated.
19) Windshield hinges no longer slotted for quick removal (I think)
20) Leaf springs changed dimensions
Okay, I took care of the easy ones. 20 seemed like a nice round number.
5)dash layout
6) heater controls
8)roll bar
9)tailgate no longer drops down
14)shoulder belts added I think
16) rear axle went to model 20
My 76 has a drop tail gate, Dana rear end and no shoulder straps;)
Thats why AMC stands for ALL MAKES COMBINED. Even they couldn't keep their years straight!
So scratch #9, #14, and #16!
Actually, I'll go along with the tailgate. The change took place with the CJ7 . And I'll go along with the seatbelts because that was just a guess. But I think there may have been a pretty good chance that somebody swapped axles in your CJ. All the 76's I have seen had model 20's. Of course you could have had a leftover. I am not a "guru" on cj specifications. But now I am curious. Are your rear springs wider than your fronts? Is your frame wider in the back?
Actually, I'll go along with the tailgate. The change took place with the cj-7. And I'll go along with the seatbelts because that was just a guess. But I think there may have been a pretty good chance that somebody swapped axles in your CJ. All the 76's I have seen had model 20's. Of course you could have had a leftover. I am not a "guru" on cj specifications. But now I am curious. Are your rear springs wider than your fronts? Is your frame wider in the back?
You think this Jeep stuff is mixed up try checking out the numbers on older Harleys:confused:
My cj5 is an 80 and does not have that feature so I'm guessing it must have been part of the 1976 changes.
Now that I have a 73 CJ5 I can really see there were huge differences. They should have renamed it the model CJ5 1/2 or something.
Try looking up parts for a 77 cj almost don't exist :D
