Nothing Over 50 MPH!
- Media
- 1
- california
- 1965 CJ-5 Buick V6 Ford T-18 4-Speed Spicer 20/18,Warn Overdrive Dana 30 & 44 w/Powr-Lok posi / both,4.27 gears 33" tires.
This same thing has happened to me. >50 and it is so unstable. I was also told steering box could be the issue. However my steering box was recently rebuilt. I have about 90 deg of free turn on my steering wheel before it will turn.
Dab,
There is a good article on this site that takes you through the process of looking............
Keep in mind there are a host of things that could be wrong..........If you have replaced the steering gear then check it off the list...........start at the steering wheel and work your way down to the wheel bearings, helps when you have someone doing the moving of the wheel while your watching all the joints. It could be universal joints, tie rod ends, ball joints, frame & suspension flexing. Long shackles will also cause that due to flex.
