oem oil pressure gauge sender and switch question
jb8376
florida
1983 CJ7 with stock nuttered 258, T4, Dana 300, Dana30, AMC 20
The po had an aftermarket mechanical oil pressure gauge installed and I want to put back the OEM. I'm hoping someone can tell me what I need to get and what I already have installed. The hose is going to an elbow above the oil filter. From looking at pics it looks like originally had a plug there. I assume I can just put one back. What I am assuming is the oil pressure switch has 2 prongs. From doing some research it seems like I should have a 3 prong switch with a sender attached to it. Any help is greatly appreciated. Sorry for the bad lighting on the pics
Yes you should have a plug by the oil filter and the sender on mine is a two prong.
The OEM oil psi setup is NOT trustworthy or reliable.
Thanks guys I think I have it figured out except for the single wire that goes to the sending unit. Does anyone know what that connector is called that pushes on to it. I think it is a right angle type plug. I need to try and find one.
Yes it should be a right angle plug and if it is like mine the wire should be purple.
I am doing the same thing to ours but have not located the wire yet that should go to the sending unit. Not too surprising considering all the backyard wiring I have already uncovered.
Good luck
