Offy intake, Holley 390 and power brakes: Will I have clearance issues
cuban11182
- CORPUS CHRISTI
- 84 CJ7: 258, T5, Dana 300, Holley 390, Nutter Bypass.
ok get a infrared temp i have one for my r/c car it helps tune it, but anyway get a reading from the top of the intake...... then get a reading from when i have placed my air cleaner. there you go i dont have the reading off hand i don't remember, its also snowing outside. so when it clears up i'll send the data! i didnt believe myslef untell i did the temp gun. if you think about it the carb is sitting on a heater!!! drawning cooler air from the passenger side which dose not have a set of headers blasting heat straight up at the air cleaner.
dont get me wrong i realize the air warms up by the time it reaches the carb but still cooler then air cleaner on top the carb.
The only problem is you have to use the gun with the hood up. Once you close the hood down you get heat soak in the engine compartment. The entire engine compartment is hot. That's why most people have air coming from outside the compartment.
I have a temperature gun that I've used to check the water temps on the jeep when it running since my original gauge was
But if you're happy, I'm happy for you.
