Oil Blowing/compression questions
SGT
- Pittsburgh, PA
- 1979 CJ7
Second Gen Chevy 350
Dana 20
T18
Skycrapper 3.5" lift
Alright, Aside from all of the other issues that my 78 CJ7 AMC 258 i6 / 4.2l has, the oil blowing out of the dipstick is the main issue that needs addressed. So with the little bit of research that I have done there is only a few things that can be the issue.
The first thing I did was get a new pcv valve and vented the valve cover with a mini filter.... and nothing changed.
So, I decided to do a compression test (not a leak down) and came up with these results:
Cylinder 1 - 85 psi
Cylinder 2 - 85 psi
Cylinder 3 - 95 psi
Cylinder 4 - 95 psi
Cylinder 5 - 95 psi
Cylinder 6 - 100 psi
Then I put a cap full of oil in each cylinder and retested and the results were:
Cylinder 1 - 100 psi
Cylinder 2 - 110 psi
Cylinder 3 - 115 psi
Cylinder 4 - 115 psi
Cylinder 5 - 115 psi
Cylinder 6 - 115 psi
So asking people that have had experience with this does this compression seem good? I believe the compression should be at AMC 150 psi...correct?
Cylinder 1 - 85 psi
Cylinder 2 - 85 psi
Cylinder 3 - 95 psi
Cylinder 4 - 95 psi
Cylinder 5 - 95 psi
