Oil Dip Stick Tube Replacement - (hurri1)
Rollbar
Florida
'84 CJ8; AMC360 w/Holley 600 CFM mechanical secondaries; TF-999 Auto; D-300; D-30F/D-44R, '86 CJ7; 258; T-176; D-30F/D-44R; '80 CJ7 304 Stock; '74 CJ5 304 Stock;
Hurri1 asked this question on the chat forum and I have an answer.
The 1992 tube and dipstick used on the '86 AMC 258 i6 / 4.2l worked great. It is within a half quart of reading correctly.
The long AMC 258 i6 / 4.2l tube and dipstick is $140 at dealership.
For the 92 tube there is a hole that worked on the block. No bending required. It is the ground stud bolt hole.
Cost 30 bucks + - 1992 dipstick with new tube.
Dipstick: 53010445AB
Tube: 53020782
Please double check the part numbers.
OR you can use the dipstick tube for a '87 yj with AMC 258 i6 / 4.2l is readily available & the same block as the '86 CJ so the fill mark sould be correct.
Part number: 33007108
Price aprox 20 bucks
Here is another thought. Would this be something you might be able to find at a u-pull junkyard? I used to get a lot of parts for other cars there.
