Oil Dip Stick Tube Replacement - (hurri1)
Rollbar
Hurri1 asked this question on the chat forum and I have an answer.
The 1992 tube and dipstick used on the '86 AMC 258 i6 / 4.2l worked great. It is within a half quart of reading correctly.
The long 258 tube and dipstick is $140 at dealership.
For the 92 tube there is a hole that worked on the block. No bending required. It is the ground stud bolt hole.
Cost 30 bucks + - 1992 dipstick with new tube.
Dipstick: 53010445AB
Tube: 53020782
Please double check the part numbers.
OR you can use the dipstick tube for a '87 yj with 258 is readily available & the same block as the '86 CJ so the fill mark sould be correct.
Part number: 33007108
Price aprox 20 bucks
Tube: 53020782
