oil leak need fixin
cymbash
Has anyone had much luck stopping the rear main leak on the AMC v8.I paid to get mine fixed, it held for about. a month the started dripping again. If there is a permenant fix. Please help!
Nothing is permanent with rubber seals. If the crank was scorned enough where it was possible a new seal would leak the mechanic should have said as much before installing it. If nothing was mentioned there is a chance it was damaged while installing it. You have to be extra careful installing the top seal to guard against damaging it. So far the ones I've done have sealed.Has anyone had much luck stopping the rear main leak on the AMC v8.I paid to get mine fixed, it held for about. a month the started dripping again. If there is a permenant fix. Please help!![]()
