Oil pump gasket
Oil pump gasket
plumcrazy
Springville, Pa.
'79 CJ5, '83 DJ5, '04 Silverado
I had a slight oil leak where the pump bolts to the timming cover, I removed it over the weekend and the gasket had failed. I went to NAPA today to get a new gasket and they don't list a part # for it, just the oil pump repair kit, which includes the gears and relief valve/spring and the gasket. Since I don't need the whole kit, what do I do? Anyone know where I can order one, Autozone only offers the kit too. Can I use some RTV instead or is there a clearence issue.
:confused::confused:
If your old one is in enough shape to use as a pattern you can cut your own.
Engine Oil
$35.00
  17.5%
