On Board Air
On Board Air
mriplaybass
Full Time Jeeper
Featured
Wisconsin
1979 CJ7 304 T18 w/6.32 lo d20 w/3.15 TeraLo D44 rear & D30 Front w/4.56 Eaton Elockers front and rear,
1959 CJ5,
1954 CJ3B,
1967 CJ5,
1947 IHC KB1,
1947 IHC KB2,
1947 IHC KS5,
1967 Mustang Coupe,
Like I need another project!:D But.........................
I have a 10 lb CO2 tank that I can use for air, but I have always liked the idea of having unlimited air for more than just tires. Converting an old AC compressor is what I would like to do sometime in the future. I know a lot of you have done this, so rather than just jumping in and starting blindly, I thought I would pick the collective brains of everyone here. Any ideas would be greatly appreciated. :)
I use a converted OEM, A/C compressor with a 5 gal storage tank.
Has a filter and manual on/off pressure switch(cut-in is 130psi/cut-off is 150psi). Also has a separator to return the oil to the comp.
You want a 'pop-off' valve(175psi)and a filter. You also want a drain on this storage tank.
Use QD couplers for hose and tools. You can vary the compressor speed with a manual throttle on the engine.
I have no problem run'n air tools and can fill my 33" tires in about 90 seconds.
The York is a self oiling compressor. Likewise, some of the Sanden compressors (SD508, SD509) are self oiling. you can tell by the large nut on the cylinder.
I ran an SD508 for several years and it worked great. You DO need an oil/air separator, and just for added security, I ran an air tool oiler in front of the compressor. Use an air pressure gauge, and a Pop-off is highly recommended (I think mine is 120psi) if you use a tank, install a petcock so you can drain any excess moisture out of it. You can either run a line from the intake to your air cleaner assembly or install a lawnmower air filter on the intake.
I run a York now and it needs a rebuild.....pressurization takes longer than it used to :rolleyes:. But otherwise, I have been very happy with it also.
I use a 2½ gallon Viair tank under my tub and plumbed two lines to both ends of the Jeep to make reaching tires a breeze.
LG and I are on the same page....lol I forgot about the pressure switch :rolleyes:
I use a round K&N 'breather' filter for the compressor. I also keep a sock over the filter to make real sure the incoming air is clean.
This system has work'd very well for me for 30+ yrs.
All sounds like good info! I know the Kilby's are nice units, but being an avid do it yourselfer, and also always trying to do it as economically as possibly, I kind of rulled out the kit systems.
A few more questions for everyone. I assume a pressure switch as is used on a shop compressor will work?
I'm not too sure about what to do regarding the oil return when using an OEM compressor.
I will have to do a little research on the various compressors that were recommended, but it sounds like the York is pretty popular.
Posi, I assume that is a York that you posted pictures of. I must be blind, I do not see where you put a sheet metal screw to keep oil from entering the discharge line. Oh yes, next time you post pictures, could you photo shop in some dirt and grime for me? I go out to my shop and feel totally lower class looking at my engine after looking at yours! :poke::D. Nice work!
I have seen York compressors mounted upright and on their sides. Does this make a difference in the oiling? My experience with AC compressors is Limited to AC.
It has been over 45 years since I had a compressor apart, so memory fails me. Is there a check valve built into the compressor to prevent the air from flowing back into the compressor from the storage tank, or do I need to plumb that in separately?
And one final question, at least for now, is it necessary to install some kind of unloader valve on the pressure side of the compressor? or is the one that is integral to the pressure limit switch adequate?
This is the one thing I purchased from Kilby Enterprises. They're about 24$
With the York, wait for posi to resond back ;) Without an oil return, and on many compressors, you will need an oil/air separator. These can be found anywhere that deals with air compressors. You will also need an inline oiler....also found with air compressor stuff
I have seen York compressors mounted upright and on their sides. Does this make a difference in the oiling? My experience with AC compressors is limited to AC.
Not to my knowledge.
There is no check valve built in. You will want to install one in-line. Mine is installed just after the exit port.
I use a pop-off valve. they have a ring that you can use to pull open the valve to exhaust excess pressure.
A 'pop-off' valve is designed to open automatically at a set psi and close at a much lower psi.
A 150psi pop-off works perfectly for releasing pressure on the system. Under 150psi and it stays closed.
Very nice set-up! :notworthy:
Nice set up! Thanks for the shopping list, should make the project even easier.
An unloader valve is a good idea. Should make for an easier start on the compressor and help it live longer. Since we aren't using these compressors for exactly what they were designed for any place to save some wear is probably worth doing. The check valve/unloader combo like duffer used is probably the best way to go. Grainger carries several of these in different price ranges. :chug:
Yes it does, but only minimally. The original design was for it to be mounted upright. Mounting it sideways minimizes the amount of oil in the base to lubricate the pistons. PS: I use to build Borg Warner York air compressors back in the day (1977).
All AMC V8s York compressors were mounted sideways from the factory.
All AMC 6 were mounted upright.
There were far more mounted sideway then upright on AMC engines. Very few were mounted upright.
