one peice install
one peice install
driver007
Canada
1981 cj5 304 v8, 300 Dana,model 30 Dana and model 20 AMC rear end
When installing the backing plate to the axle flange should a person use flat washers? When pressing the bearing and collar on should a person do the bearing and collar separate. Should a person use oil when pressing? Thanks for any help
Yes to all.
BTW-A piece of steel pipe works well for 'installing' the collar and bearing.
Lumpy or anyone else know the backing plate torque I seem to remember 35#. Any suggestions on were to obtain a copy of the service manuals?
If, in fact the fasteners are gd 8. Then torque to 35 ft/lbs.
Don't forget to use sealer on the flanges and backing plate to keep water out and the grease in.
I am a idiot I came home after work and pressed on my bearing only to realize I had the backing plate on backwards. Then to add insult to injury I put a few steel specks in to my wrist getting it off with the chisel. Now to source a bearing and pay through the nose for it. For what ever reason those bearings up here are big bucks.
Your NOT the first, nor will YOU be the last.;)
IMHO-You should order the bearings from the axle maker.
I would keep a spare set of bearings and seals on hand.
O know it can't stop there I bust my cooling system on my work car. Had a by buddy flat deck it home. Later I just wanted to go for a ride in my good CJ and when I hopped in I cut the seat with my cell phone. I must have been a jerk in my other life paying for it now. Has anyone ever had their vinyl fixed by one of the fibrenew people or someone that fixes vinyl?
