    Thank you for your support!
Build Thread Operation Money Pit
More pics 9aee9af8d22e3aa6d164848941dc83d5.webp b81040834e53d3a9632b36b4df738f00.webp
Sent from my SM-G965U using Tapatalk
Mor pics d9ee4e7c2add42d9865229ac2489d43f.webp dd1a072a9538876848f67a923a9a23b9.webp fe71a48f05532661f484df86bd38357c.webp 524e8ba1f536a94aadeaa52c2eba88b3.webp 534086bc3d04ae79c209b2274fa49ae7.webp 373713b0fe79e7bf1edbe98c39ed086c.webp
I have to buy one first. Lol.
To bad you aren't closer. Getting ready to sell my wife's 96 Cherokee with 4.0 HO with just over 100K miles and runs good. Was just time for her to get something a lot newer.
Bummer
My son and I adjusted the tailgate hinges. 4 new holes some filing and it now fits perfectly. ae38f780f4425c6b0a7dad289ff89869.webp
So, I am going to look at a AMC 258 i6 / 4.2l for sale. The ad says it has fuel injection. I believe it to be the Carter BBD carb that is a computer controlled with a stepper motor
They want a $1000.
I will be doing a leak down test, checking the spark plugs and checking the oil for glitter.
So, they sold it before I could get there. Oh well. Will 2004 grand Cherokee I6 4.0L fit?
4.0 is a 4.0 I have not heard anyone say different
Just concerned about wiring
Well, I ended up with a 91 yj 4.0L that is a stroker motor. Should be interesting to see how this works once it cools off. Only 114 yesterday.
Finally got the XJ motor into place. A few more adjustments and it will be home. d2df9b840961997907ea12313c29ddba.webp
Finally had time to start the process of placing the engine in its forever home. See this thread about immediate struggles.
https://r.tapatalk.com/shareLink/to...&share_fid=16732&share_type=t&link_source=app
I will picking up new bolts and putting the engine on the engine mouts this weekend. I will have to wait to to permanently install the motor because I am waiting for dowel pins from the engine to the bell housing to arrive. Apparently, these are important. ;)
Finally, the motor is home. For now, next I need to put dowel pins for bell housing to the motor. The PO didn't have them installed for the previous motor, AMC 232 i6 . I got lucky nothing broke.
With stroker 4.0L that I am putting in they will be important. They are shipped and I will brave the heat and put them in when they get here. ef4746c33cf48dfc45a1a43267e5a50f.webp 1c5be707d512f5c2106a302f80baa708.webp d1f9abd2b27563eb5d55ac32f72bb045.webp
The 4.0L engie is finally in its place. My son andI put in dowel pins, remated the tranny and the motor, reinstalled the motor mounts and bolted the motor mount to the motor mount brackets. Very proud to have my son along side learning and turning wrenches.
I am now on hiatus until the weather cools off. See ya in November.
Nice work so far. I'm 2 years into mine, and it's going slow. I need the distraction, and motivation...
I have the same problem. Next up is wiring. The XJ motor wiring harness kinda scares me so I will doing research the whole summer. May even bring it into the house to puzzle it out. I am only using the XJ wiring harnes and ECU for engine management. We will see how much my wife likes a dusty old wiring harness in the house on her dining room table. Lol.
Well... the garage probably doesn't have AC so...
Nope, no A/C.100+ temps in AZ are coming this week. I didn't mention in my post but I also installed power steering gear box from the same XJ. I may intall the A/C bracket in the power steering pump and reservoir bracket.
Going to get custom power hoses this morning. Hose Depot in Phoenix,AZ is where I am going. The owner is opening his shop on Saturday morning at 0900 to make me a couple of hoses. I can't say how much I appreciate his customer service. 108363cdfb70a2d42ab04393058776ae.webp
3 weeks, 0 days, 6 hours, 48 minutes, 40 seconds
