Opinion Needed
Opinion Needed
jwill22
El Paso
1984 Cj-7, rebuilt 258i, Carb-Motorcraft 2150, TFI ignition, T-176, Dana 300, dana 30 in front, Rear Dana 44, 4in lift, 33in tires, 4:10 gears
Transfer Case looks okay. You just blew out the tranny at the fifth gear cluster. A good T-176 should cost no more than $300. More if it has been recently rebuilt. No adapters required for the T-176 , however, you may need to change the length of the driveshafts. A good Dana 300 around here is $350. A T-176 Dana 300 combo should be no more than $700-800.
$1200 sounds way to high to me.
Definitely high priced, that same combo just sold locally for 400. AMC 150 for the tranny and 250 for the TC.
