Ordered a new Dana 489 rear end
TSB8C
Old Time Jeeper
- Featured
- 11
- Media
- 26
- Resources
- 1
- Solutions
- 24
- Cut-n-Shoot, TX
- 1984 CJ7, 420 HP "ZZ6 EFI" Crate engine, 700R4, D300, Dana30 front, Dana489 rear, 4.56 gears, 4" lift
My rig has the original AMC20 rear end in it. When I first got it, I was told the e-brake cable needed adjusting as it was loose and didn't apply the brakes at all. But when I first got in there doing brakes, I found that the e-brake lever inside the brake drum (attaches to the rear shoe) was gone and the cable wasn't attached to anything. I also discovered some other missing brake parts (equalizer bar and spring) as well. So I became suspicious about why someone would remove and leave out such brake parts. Oh well - new 1-piece axle shafts, re-geared it, new bearings and seals, and all new brake parts (spring kit, drums, shoes, and other missing hardware). Well after only a few thousand miles, the bearing blew apart (literally broke apart) on the side where I previously discovered the missing parts, and ruined a new axle shaft in the process. So another new shaft and new bearing and seals. Now about 10K miles later, outer seal on the other side is leaking, with bearing grease oozing out into the brake drum. So I'm done with this AMC20 rear end. I was looking at doing a disc brake upgrade to it in the near future, but no longer want to spend any more money on it. I don't know if the housing is damaged (maybe a prior accident or other issue)? Maybe one or both ends are out of round and egg-shaped somehow causing premature failure of bearings and seals? Either way, it's done. I looked at some options and decided to go with a brand new Dana 489 rear end from East Coast Gear Supply. They have a lot of options to custom build what you want. Weld the spring perches in place, change the pinon angle for a lift, proper gear ratio, lockers, Limited slips, etc; and it comes with disc brakes already in place and plumbed. They claim this is truly a bolt-in swap for a CJ based on you telling them your specs (narrow or wide trac, yoke type, etc). They supply the needed u-bolts and spring plates (for the wider axle tubes) and u-bolts for the u-joint onto the yoke whereas I currently have a strap type yoke. They are about 80 days out on deliveries, so stay tuned. In the meantime, I'll keep driving this slightly leaky rear end around in Houston traffic and an upcoming quail hunt in Navasota, and just keep an eye on it. Hopefully nothing else blows apart before the new one gets here.
