Parking brake cable installation?
class 3
- north hollywood ca
- 1976 CJ5 258cc motor, T-18 Trans 4 speed, model 20 transfer case. 4:10 gears, Dana 30 front, AMC 20 rear.
Hi, I am installing new parking brake cables and cant figure out how the cable attaches to the backing plate. The backing plate has two bolt holes which would hold the cable bracket.
While digging through old boxes of parts I came across two other similar plates which I think may be attached also.
Does the mounting plate go on the inside of the backing plate or on the back? If so, I can attach it with two bolts.
But then again, where does the other little plate go?
