Parking / E-brake Cable Removal
truk820
Chicago
1981 CJ7, Iron Duke 151, SR4 transmission
Easiest way to go about it is to pull the cable out of the sleeve some how or another and clamp that end in some vise grips. Then you have the slack necessary to remove it.
Go under your Jeep and loosen the tensioner that tightens the cables. You should have enough slack after that. Mine was located about 2 feet in front of my rear axle dead center of the jeep.
Found the tensioner under the driver side - I loosened it a bit and it gave me just enough play to pull the cable out of the top of the brake assembly. Thanks a ton, been struggling for quite a while on that one
