Engine PCV valve too long for 1986 CJ7
Hi all, I am having an issue with my Jeep and changed all the spark plugs and noticed that my Pcv valve was sticking out kind of weird. The grommets were significantly deteriorated so I changed both the Pcv valve grommet and the Pcv elbow grommet. I thought the valve was sitting funny because of the grommet but it turns out the valve itself is too long and won’t go all the way down before bottoming out. Everything I find is the exact same valve that I have but the nipple part at the bottom makes it too long. Am I losing it? I posted a pic to show how much it originally stuck out. Could mine possible be a different valve? I see shorter ones without that extra length but it says it’s for a 6 cylinder and that it won’t fit my jeep. For reference, it’s a 1986 CJ7 4cyl
Thank you all so much.
