pinion yoke wrench?
I need something to hold the yoke while I back off the pinion nut for the rear differential.
The current carrier bearings are dissintigrated which lets the carrier shift over enough so that if the weight of the jeep is on the tires I can't back the pinion nut off without the pinion just turning.
I'm taking the whole axle off (and then the front as well) so I can do a ring/pinion/carrier switch.
Is this where some one tells me why using a 24" pipe wrench was the wrong thing to do?![]()
