problems with brakes after rear disc conversion
Have lost having a good brake pedal after my rear disc conversion, no residual valve or proporting valve in use. Believe it's got to be my MC/booster combo. For those running after market 4 wheel discs what system or combo are you using.
Brakes front are SSBC conversion (Wagoneer/ 1/2 tonne pickup) 75mm piston
Brakes rear are Nissan/Suzuki conversion 38mm piston.
Using original 75 Jeep manual pedals so I think 6:1 ratio
Master cylinder/booster is what was on it when I got it, Mercedes 300d disc/disc. For those who followed my build will understand why the Merc stuff is in it.
I'm willing to change MC/booster setup if I know what I change to will definitely work.
Any help appreciated
