Problems with rear right axle shaft
brandysgunivere27
When I got the jeep the rear hub was spinning on axle. The guy I got it from told me about and what was "needed" to fix it. I replaced the shaft with what came out of it. (Dorman OE Solutions - Axle Shaft) basically axle and then hub assembly with a tiny little key that holds the hub on the axle but the axle and shaft do not spline together. I drove it across town and it was already loose, and starting to chew up the new axle. Can I replace the hub assembly with a solid hub/axle shaft? Or what do I do to fix the problem?
