Pulling engine, trans and transfer case
nivensid
I am pulling a AMC 304 out of my CJ5 , I have the front clip removed and just about everything unbolted. The T-15 and Transfer Case are still bolted to the engine. From this point it looks like I should be able to pull everything out as a unit. I have a 2 ton cherry picker and a load leveler.
Would you separate the Transmission and Transfer Case or pull as a unit?
