Engine Putting a Holley 390 back on the Clifford
JeepinMike
Belmont, Vermont
1967 CJ5, 225 dauntless, t-86, Dana 18, D27/44, 4.27 gears, 2.5" skyjacker springs, sierra blue. 1985 CJ7, 258, Clifford performance kit, T5, Dana 300, Dana 30/AMC20, 3.31 gears, 2.5 skyjacker springs, originally a renegade
That's on backwards. It should be facing the other way and fuel entering from the front.
I was running a MC 2100 (similar 2 barrel) now I have a Holley sniper EFI
Sorry for the poor pictures
What effect would spinning it 180 have? If anything I've seen pictures of them mounted sideways, which I would do if I had more room (brake booster)
If I did spin it the throttle bracket would flop to the fender side and may avoid the acc pump levers since cable would pull from a different side of the carb? Also, that would put the choke spring right over the exhaust.
Yes the choke was originally over the exhaust in the factory setup. As well as the throttle pulling from the fender side. The other thing it does is reduce the amount of fuel line running near the exhaust allowing it to be cooler.
Also by flipping it around it would give you a more natural throttle pull with the cable. As you have it now it would need to pull from the bottom to get the blades to open correctly as opposed to the top.
I appreciate the reply and I'll test fit the carburetor turned 180. It's important to note that the original Holley 390 cfm was mounted "backwards" for ~20 years and ran well for for the 5 years that I previously owned the Jeep. I talked to Clifford performance and they said it mad no difference which way the carburetor was clocked on the Clifford intake. I am open to all possible positions to mounting the carburetor, although mounting sideways does present some clearance issues with the brake booster. Thanks for pointed out which way the factory had setup was configured.
Factory would've been a 1 barrel with a downward pull via linkages. When I switched to the MC 2100 and later Holley sniper EFI based off the 2300 I used a stock throttle cable from a AMC 304 powered CJ7
M M is that cable different from a AMC 258 i6 / 4.2l cable ? I’ve been dealing with something on mine. I get a slight sticking right at the beginning, sometimes at the beginning of acceleration. The cable and linkages do not stick when I’m manipulating under the hood. Also the acceleration is very sensitive so it takes off.
Yes it is different.
I'd have to double check measurements but I believe the 77-83 AMC 304 powered 7s have a 18.225" long cable and the stock 6 cylinder is 21.5"
That’s a big difference. Interesting.
My Nickel.95,
On Some Carbureted Rigs, The Carb is turned to Stop Flooding or Starvation if you are going to do some Serious Off Roading. Mostly for climbing angles…..
Anyone can Fall Off/Down a Mountain…..LOL
WEBER Carbs sells different top gaskets to stop “Vent Flooding” for Off Road
applications.
Just a thought…..
My Nickel.95,
applications.
Just a thought…..
I ran the MC 2100 for this reason. It was a great carb for off roading (and just about anything else) although I didn't need to spin it at all. Mine came off a 72 bronco with the 302
My Nickel.95,
applications.
Just a thought…..
Turned so float bowls are side to side instead of front to back? If so that's how I would like to mount it but the brake booster is kind of in the way. Jeep will be mostly a cruiser so I might not really matter.
You can always go EFI and not worry about the float bowls
Yes, and see which way the Floats pivot.
$150.00
  75.0%
