Question about 4.0 intake/head swap
thunderlizard66
So I bought this CJ and supposedly it has a 4.0 swap done. It wasn't running, fuel pump issue. I had seen it running previously so I know it ran, However after reading the forums and searching the web I went looking and found the following:
1. No VSS, it just has the speedo cable.
2. No CPS mounted to the bell-housing or harmonic balancer
3. EGR solenoid and the ballast resistor are not hooked up
So I'm pretty sure this is a renix, because I found the Bendix solenoid panel on the fender and the valve cover doesn't say 4.0.
