Engine Question for sbc 350 swap folks
Masscj7
Lifetime Supporter
West Springfield, MA
1986 CJ7, SBC 350, Dana 300, D30, AMC20
I know several here have done this swap, did anyone retain their stock Jeep OEM oil pressure gauge? If so, what electrical sender did you use for the gauge?
I spoke to Faria Beebe today who made the gauges back then. While they had some info about the gauge, they were not able to tell me the ohm range of the OEM gauge which dictates the sender.
Best bet is buy a sending unit for a 6 or 8 cyl amc motor of that year. Same for the temp gauge. The SBC isn't any different that those of the AMCs in regards to threads both are SAE. I found using Standard motor sending units work the best.
When I did my SBC, I used the same sender from the AMC 6 cylinder with an adaptor to screw it in. I later got the Dakota Digital guages and used the senders they came with.
I think I have this in a spreadsheet at home, I'll try to remember to check. As others have said though, usually the sender and gauge are a matched set.
I found that the stock gauge is croughly 240ohms - 33 ohms and the Stewart Warner sender I got for their gauge is basically that. So I’m going to try that first, then may try can AMC V8 sender, and if none work, I’ll throw in the new Stewart Werner gauge. Thanks for the replies folks.
Rehashing this one, so I put in a sender from Stewart Warner to my stock CJ gauge. (I know I have oil pressure, I had a mechanical gauge hooked up for initial startup)
With the SW sender, upon ignition turn on, gauge sweeps to middle of range, but upon start up, gauge drops off range.
I ordered a sender for a AMC 258 i6 / 4.2l and the store sent me a two prong, what seems to be just an open close switch. Is this correct?
Seen some pics on the web, looks like stock used to have a T fitting that had both the two prong switch and also a single post/prong which I’m guessing is the actual sender.
I’d like to try a stock Jeep sender on the gauge next before swapping the gauge. Searching Rockauto, all are a 2 prong switch.
I ordered a sender for a 258 and the store sent me a two prong, what seems to be just an open close switch. Is this correct?
Might want to put this in a different post since your asking about a AMC 258 i6 / 4.2l part and not really SBC related. Just trying to get you a quicker response. Im no help with a AMC 304 and not a good enough memory anymore.
    Best for votes
    on specific items
