Question on brake booster
iCEMAN
MI
'83 CJ7 401 Auto
'01 2500HD
'49 Chevy Pickup
'05 FLHT
'47 Flathead 45
So, you guys helped me figure out what to check on the alternator concern. So on to part 2, the brakes.
Noticed that since I brought the beast back out, the brakes felt really bad. I practically have to stand on the pedal to get it to stop and the pedal goes darn near to the floor. So when I got home, decided to start with checking the fluid. Turns out, there is a leak in the booster set up.
I have upgraded to the YJ booster so we are all on the same page. Anyway, the brake Master cylinder/booster is leaking right at the junction. There is a small hole at the bottom of the MC right where it bolts onto the booster. Cannot tell 100% if it is leaking thru the hole or between the two parts.
Any ideas? Is is junk? Or is there a gasket that may have gone bad.
RJ,
there is a seal on the MC pushrod.
Napa sells rebuild kits that have the seals and o rings.
If may be more cost/time effective to put a new YJ MC on.
New M/C is on, brakes are bled thanks to a good friend and the test ride went well. YJ is back into the garage for work, so all is back to normal.
Good to hear, no brakes are a drag.
Yep, nice to be able to drive it and no have to worry about taking out someone.
Calling for some snow/ice/rain tonight thru Tuesday so should be fun to go play in.
Brakes 10 or 11
